[Laguna II] english laguna with air con problem
i am a member of the uk renault forum and we have problems with air con.
over 2200 rpm the air con cutouts and until the revs drop under 2200 rpm.
it is a curious problem, regas or pressure sensor do not cure the problem.
do you guys know - thank you
and it next week you see a blue laguna LX51 give me a beep - vendee area
Message Ven 05 Aoû, 2011 21:08
Welcome dirtyleeds
Same problem was encountered and solved here: https://www.planeterenault.com/forum/laguna-ii-probleme-de..-h-regle-t28122.html
air con compressor might to be replaced
Before, check compressor's command wire continuity: if continuity is KO, the displacement variation command is off so the compressor.
ex-Outback LTDex-Laguna II.2
