good day, I'm a new owner SCENIC 3 motor 1.6 dci. question, is it normal to hang rpm 900, regardless of the outside temperature? to -15 degrees or +20, rpm to 900 does not change. thank you.
yes, on engine warm condition, it's normal.
rpm will increase slightly when declutched.
_________________ NOUVEAU : Adhérez à l'association et bénéficiez (entre autres) du prêt d'une "valise" Can Clip prête à l'emploi + notices Renault.
Mulțumesc pentru răspuns, la scenic 2 -1.6 16v când este frig afara (-15 grade celsius) turația motorului creste la 1200rpm apoi scade treptat, la asta nu, sta nemișcat la 900 rpm.
Merci pour la réponse, quand la scène est 2-1.6 16v quand il fait froid dehors (-15 degrés Celsius) le régime moteur monte à 1200 tr / min, puis il diminue progressivement jusqu'à atteindre 900 tpm.
I apologize, I write from the phone, I think I got it. Thanks for your attention "rpm91." I understand, rpm stays at 900 rpm regardless of the outside temperature. Thank you again. A good Day.
