[Discussion] Au coeur du 2.0Dci.
Message Dim 30 Juil, 2006 13:07
Chriss51
Effectivement, sympa comme lien ;)
Voilà quelques photos, pour ceux qui aiment ;)
http://i75.imagethrust.com/t/518314/9898bdren2005engine.jpg http://i75.imagethrust.com/t/518315/9899bdren2005engine.jpg http://i75.imagethrust.com/t/518316/9901bd.jpg http://i75.imagethrust.com/t/518317/9902bdren2005engine.jpg http://i75.imagethrust.com/t/518318/9903bdren2005engine.jpg http://i75.imagethrust.com/t/518319/9904bdren2005engine.jpg http://i75.imagethrust.com/t/518320/9905bdren2005engine.jpg http://i75.imagethrust.com/t/518321/9906bdren2005engine.jpg http://i75.imagethrust.com/t/518322/9907bdren2005engine.jpghttp://i75.imagethrust.com/t/518305/9908bdren2005engine.jpg http://i75.imagethrust.com/t/518306/9909bdren2005engine.jpg http://i75.imagethrust.com/t/518307/9910bdren2005engine.jpg http://i75.imagethrust.com/t/518308/9911bdren2005engine.jpg http://i75.imagethrust.com/t/518309/9912bdren2005engine.jpg http://i75.imagethrust.com/t/518310/9913bdren2005engine.jpg http://i75.imagethrust.com/t/518311/9914bdren2005engine.jpg http://i75.imagethrust.com/t/518312/9915bdren2005engine.jpg http://i75.imagethrust.com/t/518313/9916bdren2005engine.jpghttp://i75.imagethrust.com/t/518296/9917bdren2005engine.jpg http://i75.imagethrust.com/t/518297/9918bdren2005engine.jpg http://i75.imagethrust.com/t/518298/9919bdren2005engine.jpg http://i75.imagethrust.com/t/518299/9920bdren2005engine.jpg http://i75.imagethrust.com/t/518300/9921bdren2005engine.jpg http://i75.imagethrust.com/t/518301/10234bdren2005engine.jpg http://i75.imagethrust.com/t/518302/10235bdren2005engine.jpg http://i75.imagethrust.com/t/518303/10236bdren2005engine.jpg http://i75.imagethrust.com/t/518304/10237bdren2005engine.jpghttp://i75.imagethrust.com/t/518287/10238bdren2005engine.jpg http://i75.imagethrust.com/t/518288/10239bdren2005engine.jpg http://i75.imagethrust.com/t/518289/10240bdren2005engine.jpg http://i75.imagethrust.com/t/518290/10241bdren2005engine.jpg http://i75.imagethrust.com/t/518291/10242bdren2005engine.jpg http://i75.imagethrust.com/t/518292/10243bdren2005engine.jpg http://i75.imagethrust.com/t/518293/10247bdren2005engine.jpg http://i75.imagethrust.com/t/518294/10248bdren2005engine.jpg http://i75.imagethrust.com/t/518295/10759bdren2005engine.jpg http://i75.imagethrust.com/t/518323/10760bdren2005engine.jpg
Message Dim 30 Juil, 2006 14:07
Salut Chriss51,
Tes photos sont sympa aussi :kiss:
C'est quand mème bien quand on peut avoir sous la main du détail :wink:
Je pense que ça devrais plaire a beaucoup de monde ce genre de précision (vidéo/photos).
A@+ JMT31.
Chriss51
En double ? Toujours en Généralités ? Je ne le vois pas :/
Les photos des courbes de couple et de la nomenclature restent petites. N'y a t il pa moyen de les redimentionner ?
Laguna Estate, Aubade inside.
Chriss51
Message Dim 30 Juil, 2006 15:07
En HD ? Si ;)
J'ai un truc à ffaire à la maison, et après, j'irai les chercher en HD ;)
A toute ;)
Chriss51
Il faut s'abonner pour les voir ?
Chriss51
Ah ça marche pas ?! :ko:
Mince...
Alors je vais les enregistrer sur mon ordi et les publier comme précédemment ;)
Chriss51
http://i73.imagethrust.com/t/559378/1.jpg http://i73.imagethrust.com/t/559379/2.jpg http://i73.imagethrust.com/t/559380/3.jpg http://i73.imagethrust.com/t/559381/4.jpg http://i73.imagethrust.com/t/559382/5.jpg http://i73.imagethrust.com/t/559383/6.jpg http://i73.imagethrust.com/t/559384/7.jpg
Merci c'est mieux, mais il y a des doublons :wink:
Chriss51
Message Dim 30 Juil, 2006 16:07
J'ai cru aussi, mes les 4 courbes, la première, c'est une 2.0 dCi 125kW, la 4°, c'est une 2.0dCi 127kW, et les deux 110kW n'ont pas exactement les mêmes dimensions, elles doivent donc être légèrement différentes ;)
Si doublons il y a, c'est sur Média Renault ;)
125kw=170CV
127kw=173V
110Kw=150CV
Le 175cv ne serait qu'une appellation commerciale, un peu comme le2,2l dCi et ses 150 CV ?
Chriss51
Ca fait plus vendeur, plus accrocheur, puisque rond '175" que "173" ;)
Message Dim 30 Juil, 2006 20:07
Si ça se trouve peut ètre que les 175cv on les a, à 4000Tr/mn en 6eme.
Comme pour les 150,120 et toutes.
La puissance commerciale on ne peut jamais y aller. :prie:
Robocop91
Qu'est ce tu pense de la vidéo :?: ::hello_010::
A@+ JMT31.
jmt 31. a écrit:
C'est bien possible.
POURQUOI 170 ET 173 CV ?
Je te montre :?: :mrgreen:
Message Dim 30 Juil, 2006 21:07
Je pense que la puissance moteur peut se pendre.
Avec le régime et la pression de suralim :wink:
A mon boulot on fait comme ça pour réparer ce type de machine :arrow: http://photostp.free.fr/galerie.php?code=dev
Convertisseur callé, controle du régime max et controle de la pression de sural. Si tous ces controles sont correcte, la puissance est corecte.
Et si c'est pas bon on touche au réglage de la ppe a injection, qui fait varier le régime.
Toutes nos données d'atelier sont là sur SIS (Service Informatique Système). :arrow:
Base de données de CAT SIS
Obtenir le suivant quand vous achetez SIS :
Le CAT partie le livre.
Manuels d'entretien techniques de réparation de CAT.
Opération et entretien de CAT.
Instructions spéciales de CAT.
Spéc. d'exécution de moteur de CAT.
Résultats d'essai de CAT pour tout l'équipement de CAT.
Guide de l'information d'outil de chat.
Le CAT partie l'information et la nouvelle enquête de pièces.
Quel est SIS ?
SIS est la base de données de l'information de Caterpillar aux services, aux pièces et à l'entretien.
Il fournit des informations détaillées sur des machines, des moteurs et des pièces.
Niveaux spécifiques de l'information (les instructions spéciales, livres de pièces, service anual, etc.).
Je vais faire le nécessaire pour essayer de prendre la puissance sur la mienne.Ca vas me prendre du temps mais je vais essayer de prendre les mesures aprés les congés.
A@+ JMT31.
jmt 31. a écrit:
A mon boulot on fait comme ça sur ce type de machine :arrow: http://photostp.free.fr/galerie.php?code=dev
Je les ai reconnues, c'est des SsangYong Rodius !
:mrgreen:
Message Dim 30 Juil, 2006 22:07
Robocop91 a écrit:
jmt 31. a écrit:
Pour faire vendre, et puis les journaliste de magazines Auto, qui connaissent rien d'autre que leur stylos, sont pas a ça prés. :wink:
A@+ JMT31.
Il ne faut oublier que le 2.0 dCi n'est pas vendu que sur le marcher Français.
Dans d'autre pays, quelques cheveaux de plus peuvent faire changer de catégorie fiscale :-?
Par exemple en Balgique, les Meg II.1 1.9 dCi font 115 ch contre 120 ch pour la France à cause de cela.
Mais la différence pour le 1,9 dCi FAP en France 125 ou 130CV a une explication aussi ?
Message Lun 31 Juil, 2006 09:07
Oui : 125 ch sur Scenic II = 7 cv fiscaux
130 ch sur Scenic II (existe en allemagne par exemple) = 8cv fiscaux. Souci, les flottes ont une surtaxe trés conséquente (le double) si plus de 7cv fiscaux.
La Megane avec le 1.9 Dci ne propose que la version 130 ch avec 7cv ;)
La puissance fiscale est calculée en partie avec les rejets et comme le Scenic est moins aerodynamique il consomme plus et rejette donc plus => limité 125 ch pour rester en 7cv fiscaux ;)
Chichi1er...
alfb59
Message Lun 31 Juil, 2006 10:07
Ceci est vrai pour le ScénicII phase 1 uniquement ... car sur le phase 2, le 1.9dCi FAP va passer à 130ch et 8cv pour la France.
(Cause : retour en arrière de la réglementation ... :roll: )
Idem sur la LagunaII.2 avec le 1.9dCi FAP qui passe à 130ch pour la France (depuis juillet 2006) ... et reste en 7cv si monte en 16' (sur berline uniquement) et passe en 8cv si monte 17' et/ou Estate :wink:
PS: :oops: on est un peu HS là non, car cela ne concerne pas le 2.0dCi :-?
Fin du HS : :oops:
On continue là bas : https://www.planeterenault.com/forum/viewtopic.php?t=17582
Chichi1er..
Edit pour modif du lien, merci Robocop
Donc ces quelques chevaux font gagner des CV fiscaux.
Chichi es tu sur de ton lien ci dessus ?
alfb59
Message Lun 31 Juil, 2006 13:07
De toutes façons le prix de l'assurance était la même pour les 2 versions (ceux qui prenaient la version IMPORT de 130ch et 8cv payaient le même prix que la version française de 125ch et 7cv), car les assureurs ne se basent plus sur la puissance fiscale mais sur la valeur à neuf du véhicule ...
Il n'y a donc "que" le prix d'1cv supplémentaire à s'acquitter avec le CarteGrise :wink:
On repasse a la chaine de ditribution? fini la courroie ,fini l'entretien de la distribution alors des economies en perspective LOL
Scenic II 1.6 16v confort expression vert cuivré
Yaris linéa techno 1.4 D4D gris titane métalisé
Salut mils,
Pour s'avoir s'il y a des économies en perspective, il faudrait que des possesseurs de ce 2.0L Dci, nous face part de leur manuel d'entretien, sur les révisions, histoire dans connaître un peut plus.
Avec des photos des textes, ce serait sympas de le s'avoir car ça pourrais être aussi bien un argument d'achat :roll: :wink:
A moins que Renault est inclu le tarif de cette révision 'courroie de distribution" dans le prix de vente.
Comme ça, ni vue/ni connue :shock:
A@+ JMT31.
Message Lun 31 Juil, 2006 14:07
Robocop91 a écrit:
125kw=170CV
127kw=173V
110Kw=150CV
Salut Robocop91,
Pour parler des puissance Din/kw, regarde ce que j'ais sur mon prospectuce.
1/
https://www.planeterenault.com/ftp/ftp/jmt_31..Prospectuce_LAGUNA_II.2_2.0L_Dci_001.jpg
2/ Si tu suis les lignes correspondante, tu veras les chiffres.
Donc 127KW a 3750Tr/mn pour 175cv Din.
https://www.planeterenault.com/ftp/ftp/jmt_31..Prospectuce_LAGUNA_II.2_2.0L_Dci_002.jpg
3/
https://www.planeterenault.com/ftp/ftp/jmt_31..Prospectuce_LAGUNA_II.2_2.0L_Dci_003.jpg
4/
C'est tirer de ce prospectuce là,
https://www.planeterenault.com/ftp/ftp/jmt_31..Prospectuce_LAGUNA_II.2_2.0L_Dci_004.jpg
Ce prospectuce est dispo dans ttes les concessions de France :mrgreen:
Désoler pour la qualité des photos mais c'est un camescope qui a l'option APN mais avec moins de pixels pour la photos.
A@+ JMT31.
Merci pour la doc commerciale.
mais 1kw=1.36cv. ensuite rono fait ce qui lui plait sur son catalogue, quand il indique les puissances C'est bête, mais pour moi 100CV c'est plus parlant que 74kw.
alfb59
Message Lun 31 Juil, 2006 15:07
Sauf que la puissance réelle du moteur est exprimé en kW, et ensuite converti comme cela arrange :roll: en ch.
Cela vient de notre culture, dans d'autres pays on ne parle quasiement qu'en kW :wink:
PS: 127kW * 1.36ch = 172.72 ch ... mais cela n'enlève en rien les qualités de ce moteur : qu'il fasse 173 ou 175ch, je le trouve hyper souple et avec du répondant quand il le faut ! :P
Message Mar 01 Aoû, 2006 15:08
