[Espace IV] Entrée AUX et Option DVD vidéo
optimisten
Jeu 21 Juin, 2012 16:10:27
| pedro78200 a écrit: | Hi !
I'm sorry but you can't connect the gateway on your cabasse.
You've got the cabasse 6CD charger, the gateway is an charger-emulator which is normelly connected where you're 6CD charger is already connected.
You can't have both emulator / cd-charger
OK, I was afraid of that.
But can I disconnect the CD charger, and connect the Gateway/emulator instead?
Merci!
optimisten
Losange d' Or
Jeu 21 Juin, 2012 18:11:14
Of You do That You can't drive your cabasse...
_________________ Actuelles :
Laguna II.2 V6 210ch Initiale 2005 | Alfa 156 ph2 1.9 jtd 16v 2003 | Corsa 1.2i City 1996
Ancienne :
Sierra 1.8 GL 1986 | Clio II.2 1.2 16v Expression 2004 | Mondéo I.1 1.8 16v 115ch GHIA 1993 | Laguna II.1 1.9dCi 120ch privilège 2001
optimisten
Jeu 21 Juin, 2012 21:40:01
What do you mean? Will I not be able to listen to the radio/aux/mp3 if I disconnect the CD changer? Why?
It stands clearly on Densions website that my car with the excact specifications is compatible with the Gateway Lite...
Merci!
Losange d' Or
Ven 22 Juin, 2012 07:33:58
I mean, tu ne peux plus controler ton ampli si tu débranche ton chargeur puisque la partie controle / charger est sur le meme boitier... Tu va te retrouver avec un ampli tout seul dans son coin...
Ancienne :
optimisten
Ven 22 Juin, 2012 15:29:10
Ok... I'm quite desperate finding a way to get this working, since I have hundreds of miles in the car this summer
Is there any opportunity to fix it? Can I replace the head unit with one without CD changer?
Merci baucoup encore!
I appreciate your help and knowledge very much!
Losange d' Or
Ven 22 Juin, 2012 16:12:29
Do you have GPS carminat?
Ancienne :
optimisten
Ven 22 Juin, 2012 16:28:04
Oui
Responsable Technique
Ven 22 Juin, 2012 17:02:43
| optimisten a écrit: | But can I disconnect the CD charger, and connect the Gateway/emulator instead?
No !
The 6 CD charger is the remote of your radio.
There is actualy no solution to add virtual device on your radio.
_________________ Responsable Technique du Forum
http://j2c.org et http://spam-rbl.fr
Laguna II.1 Estate Dynamique 1.8L 16v (2002), GPS CNI 2 Cabasse, Radar de recul, Attelage, Jantes 17" Sylverstone, Feux Xénons, Régulateur de vitesse (by PR), Synthèse Vocale. 92 500km (compteur phase 2)
optimisten
Lun 25 Juin, 2012 17:42:10
OK - I see... But can I for example replace the readio with one without CD changer? Or should I rather by another car? ...ehehh
Losange d' Or
Lun 25 Juin, 2012 17:53:04
It dépends if You have à GPS carminat. If not You CAN replace it, but If You have one You Will lose the GPS
Ancienne :
j.marc
Lun 18 Mar, 2013 09:36:21
Merci pour ce tutos j ai effectivement pût brancher mon câble commandé chez cable renault sur l amplie cabasse par le vide poche en haut a droite j ai eut juste à enlever les broches du connecteur jaune du cable pour les clipser car a l origine j ai l ensemble des connectiques et le shema m as été fort utile merci encore l auxiliaire est bien présent maintenant et fonctionne super
_________________ grand espace IV 3.5 l v6 245 cv de 2002 gpl puis lincoln navigator ultimate de 2007 et toujours le pt cruiser 2.4 l gt turbo de 2003 et revient avec espace iv ph 2 initiale v6 3.5 l de 2008 en gpl
tiloi29
Lun 22 Avr, 2013 17:40:59
bonjour a tous je vient de faire le cablage, ca fonctionne super bien.
merci pour l'astuce.
juste une précision je n'est pas eu besoin de cabler la masse.
